A predecessor installed a new trunk lid seal which doesn't allow the lid to close and latch. It has the corners molded in a single piece unit. The lid will close completely without the seal installed.
Is there a seal known to fit?
Thanks,
Dan
You may have the old style that are solid foam right through (you can feel by squeezing it) and they will hold the lid up a bit.
The newer ones are a moulded hollow section (Drake I think) and they collapse easier allowing the lid to close. Both have moulded corners.
we run in to this problem quit a bit on our new restorations. The new rubbers are thick and stiff. we often have to re adjust the trunk latch to a looser setting and over a period of a few days adjust it back once the new rubber compresses and starts to form fit. This usually works for us and generally provides for a nice watertight seal.
