'48-'52 F1 Spindles
1stGrumpy
Clarksville
Ar
I'm looking for a pair of squareback front spindles from a 1948 thru 1952 Ford F1 P/U...
I have a lot of front suspension for 48-52 F1s. I just don't understand what you need by your description. I'm not familiar with that part as described.
Do you have a picture or a part #?
Here are a couple of pictures... the 1st picture is the roundback spindles and the second is the squareback. They both had the same bolt hole spacing and kingpin diameter, the square back used a little longer (1/2") kingpin. The round back are pre war and the square back are post war.
Let me take a look when I get home after woork. I've parted out a lot of 48-52 trucks and seem to remember that they had a roundback spindle, like in the 1st picture, but I will double check for you. I have three sets with the spindles still attached.
