48-52 F1 pedal bushing issue
i just installed new brass bushings in my 48-52 f1 pedals. I'm having an issue getting the shaft to fit into the bushings now so i can assemble the pedal assembly. Do these require a hone or anything? should it be a very tight fit?
After installation, MOST bushings require honing to size...a reasonably snug fit with lubrication. Even a 1/2" wooden dowel with a flap of sandpaper mounted in a drill can be made to work as a hone. Coop
318551
You probably just have some burrs on the edges. I ran a brake hone until the pin fit. Clean the bushing after each hone pass so that you do not go too far and make it loose.
JB
Be sure you have opened the bushings to allow lubrication. Just drill through the grease fitting hole before you reinstall the shaft, using a drill bit small enough to protect the grease fitting threads.
