47 V8 distributor rebuild
jimloiselle
I am rebuilding a 47 distributor and need to know what serfaces and bearings to lube and what type of lube to use. Should the grease be high temp and what type. Also should the vaccuum brake piston be lubed? I have searched various repair manuals and most are not spacific. Thanks.
There are no bearings in there. Just clean up and regrease with,i use white lithium greaseon all surfaces that move or slide. Check bushing clearances,must not be excessive. Yes grease and oil vacume plunger. ken ct.
