Hi all,
Yesterday while pondering starting issues, I noticed the battery cable connection to the starter motor was loose. Tried tightening it only to discover that the thread on the brass stud is so beat it's almost non-existent, so the 1/2" nut just spins around. Not a prob (I thought to myself), I'll just drop the starter motor out and re-cut a new thread onto the existing stud. Getting the starter out proved easy as pie. When I took a closer look at the battery connection it became obvious that the solder joint to the stud inside the motor has failed, causing a bad connection (the terminal becomes hot while cranking). Has anyone tried re-soldering these connections without completely dismantling the motor?
