kelly.ga
Thanks to all for the help. I measured everything that you guys said and found that when I put the Push rod on High Cam, I could barely feel it when I put the pump and stand back on. I took it back off and welded a *** on top of the rod and the vacumn jumped up immediately, not as high as I wanted so I welded a tad more. after I put everything back together I turned on the elec pump to prime and the car started almost immediately. I then turned the elec pump off and the car kept running for at lease 15 min until I turned it off. I think WE got it. Thanks fellows, you're the best.
