dwick01
I was going down the highway and started hearing a loud noise coming from the front of the car and it sounded like something in rotation and my temperature gauge was fluctuating. I pulled over and it stopped and then repeated the same thing when I got back up to speed. I pulled over again and sat for a little while and went going again. It didn't do it again. I had no problems after leaving the car show and going home. My temperature gauge did not fluctuate at all and stayed right in the middle.
The water pumps are good and tight, but I can wiggle the fan back and forth and the sound it made seemed like it was very close to what I was hearing.
My fan assembly is the electric one that works off water temperature and not the normal fan/hub assembly.
My question is, what all would l need to buy to get rid of the electric version and get back to normal fan/hub assembly? I would think my fan blades and brackets will work fine but not sure what else I need to get.
