Oldrod47
I got caught in the Tenn/Ky rains last month and found my trunk soaked when I finally got home and emptied it out. Located the leak about 4-6 inches inboard from the drivers side trunk hinge when I washed it. How do you adjust the trunk lid ? Can you shim the hinge? Or do you somehow raise up the weather strip?
Also , cowl vent leaks like a sieve, have tried double gaskets and it still leaks.
May have to get bilge pumps the way its leaking.
