'47 coe
I have a 47 COE and off-hand I recall the width between the dual rear wheels to be about 85-86 inches. That's too wide for a standard trailer (almost all trailers have a standard width axle) and the inside distance between fenders on most trailers is 83 inches. However, if you remove the outer two dual wheels, it should fit...or find a trailer with the bed mounted over-the-tires.
I'm at work and this is all from memory. I'll try to remember to check and post another answer if my memory is failing.
COE Dan
With duals, the outside width is an inch or 2 less than 7 feet. As COE Dan suggested, removing the outside wheels reduces that by nearly 20 inches total.
The front wheels shouldn't be a problem.
Tom
