We've supplied needle roller thrust bearings for 20's -30's Dodges &have had NO problems with wear at all what so ever.These AREN'T needle roller cages but needle roller thrust, which is a washer with needle rollers pressed into it ,commonly used in torque convertors&manual transmissions for there load carrying capacity, the trade part number is : TORRINGTON NTA thrust needle roller assembly&TRA/TRB/TRC for the washer assembly which the NTA thrust needle roller bearing sits on they're availa ble in differrent dimensions &thickness, they lighten up your steering.
