Hi,
I'm getting closer to finishing the install of a rebuilt transmission and new clutch and pressure plate in my 47 Tudor. I'm confused about a couple things, the through out bearing has a spring that pulls it back and the clutch pedal also has a return spring on it. It seems like the spring for the pedal over rides the spring on the through out bearing? The spring for the pedal hooks to the pin on the back side (clevis end) and wondering where the other goes? Mine was straight down and hooked to the crossmember. To adjust the clutch pedal free play, do I just have an inch of freeplay at the pedal with the floorboard installed? If I do this the bearing is a fair amount away from the fingers on the pressure plate. When I adjust the bearing closer to the fingers on the pressure plate the pedal is higher than the floor pan.
Thanks, Don
Thanks, Don
