I need to know how to full field the regulator to see if my generator is working or if I have a bad regulator. Last weekend I noticed that the car was not charging very much. I tested the battery and it shows 6.22 volts with the car not running. When I start the car it shows 6.07 volts and if I turn the headlights on to load the system it drops to 6.03 volts. It is stock, 6 volt with positive ground. I looked at the Powermaster alternator that looks like a generator over the weekend and not sure if that is the way I want to go. I know many guys put a GM one wire alternator on, I'm sure they work but it sure looks out of place when the hood goes up.
Thanks
Don
Thanks
Don
