460 motor/C -6 ******
Scott Brownell
SantaMaria
ca
Price
200.00
460 Lincoln Motor. Came from a Lincoln Continental before is was scrapped . Numbers on the motor say C9VE-B. Motor is all apart and stored in barn. Comes with block(never touched) heads, valves, valve covers, push rods, cam(still in block) cast intake 4 bbl, water pump, power steering pump off the crank, crank never turned, oil pan, can't find carb. $200.00 for the motor and you pick it up. Will have motor and trans at the Big 3 swap meet in San Diego if you want to see it there. Also have the strange looking C-6 trans the goes with this motor. $200.00 for it too. SOLD
