Not sure what is being asked here. The pulley does come off the pump. There is a tool to grab the pulley, it is a press fit, the same tool is used to push it back on. The front harmonic balancer on the crank shaft is also pressed on, the pulleys mounted on it come off with four bolts that hold it to the balancer. Are we close with this?
