makemc
just to follow up, I got the radius arms installed and the car seems
to ride and drive even better than it did before, thanks for the help
and advice..I've got a tip on removing the hubs, an old friend told
me, after getting the wheel of the ground, to take the nut off the
spindle and put it back on backwards and turn it until it is flush with
the end of the shaft and then with one hand on the tire pulling, hit
the nut hard with a 3lb. hammer 2 or 3 times and the hub should
pop loose, I tried it and it worked great, I only had to remove one
hub to install a new bolt that was missing, the other side the bolts
stayed in place so I could get the radius arm on and start the nuts.
so all is well with my 46 coupe, for now,....
