S sdtaylo Junior Member Mar 16, 2014 #1 My main leaf in the front is cracked. Recommendations to fix or who to go to for replacement? Thanks
Talkwrench Well-known member Mar 16, 2014 #3 There should be a spring or suspension works in your area just get them to make you a new one.
Ross F-1 Well-known member Mar 16, 2014 #4 If one has gone south, the other can't be far behind. Good opportunity to replace both, and the pins and bushings.
