P prez Junior Member Jul 29, 2015 #1 greetings from New Zealand reassembling a 46 business coupe my perch bolts tight fit in axle but loose fit in radius rods is this normal ? does the taper under bolt head and taper nut do all the clamping necessary ?
V8COOPMAN Well-known member Jul 29, 2015 #2 You've got it.........that's normal, and exactly how it works. DD
