46 help needed please
416Ford
Trying to put my 46 back together after 18 years and I have too many of some parts and not enough of the ones I need.
I am trying to figure out what the length of the rear door channels are and witch one goes where?
I have one original front window that still has a track on it. Track measures 16" and the holes are 7-7/8" center to center.
Do the tab mount to the inside of the car or the outside?
THIS QUESTION ANSWERED
As for the back doors..... I do not know what goes in there? I may have one but I don't know.
Please help...
Thanks, Dave
Photo of the other front channel.
Re: 46 4dr Sedan window track
Really could use the help guys/gals. Short door coupe would be the same for the front door track direction?
Not as much help as I seem to need. Image 19 is the only thing close. Shows the mounting bracket on the inside of the channel. Still not sure how long the rear ones are.
Thanks
Thanks
That is my recollection from the last time I had my door apart just a month ago - the tabs are toward the inside of the car.
Still need a little help here. If someone has a 4dr with the back door panel off.
Looking for the measurement of the track and distance from first hole to door vertical track(need to make sure I get the track mounted the bottom of the glass in the correct spot).
I have the glass and just need to get it installed.
Thanks
