46 Ford Sway bar advise needed
Dean, is there any room to move the anti-roll bar pivots forward just enough to create a clearance? I'm talking about the front end where the bar mounts to the chassis. You might be able to slot some holes or drill new ones and move the bar just enough to get the clearance you need. That said, There may be something in the way, stopping you from moving it forward.
Of course, if the links could be fitted the other way up, that would be the easiest solution.
Mart.
As someone else suggested, your shock links should go down from the axle bolt to the sway bar. It looks like you have the proper short shock links. Call me if you want to discuss further. 303-494-1628.
Rich
Good news all, managed to flip the sway bar below the shocks. Just want to take the opportunity to thank you all for your time and help, very much appreciated
All the best
Dean
