Kevin - Illinois
Picked up a 46 Super Deluxe which does not have locking doors. Does anyone make a door lock kit for this car? Thanks! Kevin
The key is about 3.75" below the handle mounding. And, the interior handles will lock the doors from the inside. As Stud said above, I'd start by pulling the door panel and see how a PO might have filled the key mechanism.
You could lock it, but how would you unlock it? That's why I would assume some type of unlock provision. Would be a pain when it get accidentally locked if not!
I lot of guys I knew "back in the day" shaved the door locks AND handles. It was almost as popular a "nosing and decking". They removed the locking mechanism on the vent window on one of the front doors so they could just push it in, reach inside, and open the door. When you pushed the vent window shut, it was pretty hard to tell it was not locked unless you knew what to look for.
