46 ford steering problem pulls to right
after going over the front end of 46 ford everthing checked out exept caster was low 2.5 positive green bible says 4. to 8.5 i now see wrong spring pins to long by 1/4 inch and the taperd wedge is missing under front spring bible says it gives more positive caster no dealer list it part no 5336 any help to find would help spring bushings no problem dealer item pressing i see is a challinge thanks dave
Spring height and the built in angle in the wish bone will be determing factors in the castor angle... I cut the 32 wishbone in my model A to get the angle... You can add other metal, or make two cuts and turn a piece upside down so you don't lose the length... I included the 4 or so degrees that I would lose when I dropped the front axle, for 11 degrees... Which I like, having given up the idea of dropping the axle... Karl
