have a 46 coupe , flathead v8 and still 6 volt , have a starting problem that has me stumped , starts well when using it daily or weekly ,
if i leave the car sitting for 2 weeks or more , it will not start of the key ,
tried engine start , tried jump starting with 12 volt , will not fire .
if i clutch or bump start it . it will fire straight into life and sit there at an idle ,
run the car for a few minutes and then turn off . it will then start of the key like it should . but a week or so later , will not start .
this has me stumped , .
have checked timing . points look fine . have cleaned them .
replaced the cap and rotor. checked battery voltage . is at 6.4 volts
any ideas on what to look for next .
flathead engines are new to me . any help is appreciated
