T tow truck Junior Member May 4, 2013 #1 Hi just recently purchased new master cylinder for 46 ford coupe and hole that connects to brake pedals is larger than original what is the best thing to do in this case?
C Charlie Stephens Well-known member May 4, 2013 #2 Take a few pictures to see if you have the correct parts and exactly what you are talking about. Charlie Stephens
T tow truck Junior Member May 4, 2013 #3 Everything else seems correct should have been more specific mounting holes are correct but inside center hole is larger on new master cylinder thanks
Kube Super Moderator May 4, 2013 #4 tow truck said: Everything else seems correct should have been more specific mounting holes are correct but inside center hole is larger on new master cylinder thanks Click to expand... Do you mean the clevis? If so, swap out the clevis with your old one.
1931 flamingo Well-known member May 4, 2013 #5 Is he talking about the bore of the m/cyl?? Paul in CT
