46 Ford Hood Hinges,Help
46vette
I need help,on where the brackets,with the springs attached,are bolted on to the existing hood hinge assembly. Does anyone,have a picture of how,and where these are attached,and how. I just bought this 46 Ford,and trying to get things back the way it should be. Not familiar with how they should be attached. Thanks for any help.
Wendell
there should be a triangle like part on the inner fender ....that is where they would bolt to. i can try to post a pic if needed i have a 46
Thanks,for the info,AlDeBear,I will check it out. Looks like,I have a lot of help,from you all,and I really appreciate,you all for that. That is what it is all about.
Thanks,
Wendell
46fordnut,Thanks,you can send me a picture,if you want to,I need all the help,I can get. My Email address: Wdavis14@woh.rr.com, I think 46woodie,is sending a picture,also. The more the merrier,Thanks.
Wendell
As far as I know your '46 is the same as my '47. Here's how my hinges are set up - the same as they've been for 65 years.
Upper end of "knee" brace where attached to hood.
Side swing arms:
Hope this helps.
Old Henry,Thanks, that is exactly the picture,I was needing. Really detailed,and easy to understand,how they are attached. I may have a problem with the driver's side. Previous owner has a power brake booster right where the lower bolt goes,probably have to do some bending. Thanks,for your help.
Wendell
