51woodie
I need some suggestions on where to look for blockage in the carb on my stock ’46, 59AB with Model 59 carb. The engine started idling rough and these are the steps I’ve taken to troubleshoot the condition.
Vacuum at idle is steady at 20”, shorting individual plugs gives little change in RPM. Idle is 525 RPM
Compression is 120/125 on all cylinders. Plugs 1, 4, 6, 7 are a bit sooty, plugs 2, 3, 5 and 8 are dark tan.
Left idle mix screw in and out slows idle, right screw in slows idle but out makes no change.
I changed the carb out with a spare and the rough idle is gone.
My assumption is there is a blocked passage somewhere, and the question is where do I start to look as I disassemble the carb?
