Mountain Dew
I'm a Model A guy from way back and new to these early V8's. I recently acquired a 46 Super Deluxe that I am working the bugs out of. The right rear wheel was making a racket so I pulled the wheel to check things out. It has these drum retainers installed on the backing plate. It was scraping the drum. Did Drum retainers come on the 46 Ford originally? Are these really needed if the rear hub nut is torqued and cotter key installed?
I reformed them and took it out for a road test. The racket is gone but the drum is showing 185 degrees F. The Emergency brake does not seem to be hanging up. Is there any way to back the shoes off? I can barely spin the wheel by hand.
