46-48 Ford Firewall Wiring Clips
peewee2you
Elk Grove
CA
Hello, looking for 47 Ford Firewall wiring harness clips, I believe it uses 2 or 3. I am also looking for the starter cover that goes over the starter spring on a 59AB block, looks kind of like a rattle can cover.
Attached is a photo of the clip I believe I am looking for.
I've got the clips on a parts car. It has 3; want a picture before I remove them?
I'll do some more checking, may have the cover you want.
Where do you want them sent? No charge.
Dick
Dick,
A photo probably save us both some time, even though you don't want to charge me, if they're not the right ones, I don't want to take them from you, I also appreciate you checking on that cap. Address:Peter LaRocca 9596 Mainline Drive, Elk Grove, CA 95624
