My 8BA had an 11” clutch and my flywheel was not usable. For an 8BA be sure that any replacement flywheel you get is for an 8BA (not an earlier V8). The easiest way to tell is if the pressure-plate bolts are drilled all the way through. If they are blind, it is an earlier style and will not work (even though it will bolt up, I found out the hard way)! Also note that there are 2 different styles of pressure plate. The “Long” (Ford) style has 6 bolts in 3 pairs close together. The “B&B” (Mercury) style has 6 bolts equally spaced. Apparently, the B&B pressure plates are getting scarce. The clutch disc is the same either way. I looked into redrilling a flywheel, but it was less expensive to find the correct used one. I know this is late and you need early, but maybe this helps someone.
