42-48 ford convertible window crank part #
ibslamed
Attempting to find out what the difference is between the following ford part #'s.
11A-7623200, 11A-7623201 = right & left front regulator assy. 46-48 ford convertible.
11A-7623200-A, 11A-7623201-A = right & left front regulator assy. 46-48 ford wagon.
Questions:
1. I am attempting to replace a convertible window crank shaft......... I have located a 21A-7923205-S replacement part but it is for a wagon. will they interchange? Any help would be appreciated.
Thanks.
I am looking for both r&l cranks for a convertible... I have the regulators but both have broken square shafts........
I thought you wanted the crank handles. I think what you are looking for are the regulators. The wagon regulators will not work in a conv. Do you have a 42 body parts book? If so, you can just how very different they are. Conv regulators are very hard to find. If you have your two and they are not all rusted and broken, you should try to have a small piece of square stock welded on and then drilled and taped
