42 46 early 47 cowl molding
dono50
Southington
Ct
Wanted to buy-cowl molding,drivers side for 42, 46 or early 47 Ford any body style, would buy both sides if you have a set. The cowl molding fits between the door and hood.
Hi, I think I have the cowl moulding you need. It is stainless, about six inches long, one and 7/16ths wide, and has a slight crown in the middle. I think the later moulding is more rounded. However, most of my parts came off Woodies and they may be different. I do have one oddball cowl moulding that has the raised center about one inch up from one edge and about one half inch from the other edge. It is 5 and 3/8ths long and 1 and 3/8ths wide, the tapered end goes toward the door if the crown part of the moulding is 1/2 inch from the top, then this is the passenger side. If it is the other way around with the one inch to the crown being at the top, then this is the drivers side. I suspect this is the one you need but call me at 802-869-2688 or e-mail me jen.toby@yahoo.com so we can clarify what I have, with what you need. Thanks, Toby
