Hey Lawson thats a great idea,i will use it on the next time i remove it. Should also work on helmet ones,dont see why not. thanks ken ct.I put studs in mine. That way it is easy to make sure you have it aligned properly. Place crab on studs then turn the rotor till it seats correctly and the distributor sits flat on the engine, then put the nuts on and tighten.
Way back in time there was a Ford bulletin on distributor bolts. There was a larger shoulder on the 5/16-18 bolts to take movement out of the distributor. G.M.
Havent broke one yet but have had a few guys insist it went on correctly ,but how did you break the housing i dont know is usually the answer i get yea right. ken ct lolYep, it will work on both. Cuts down on broken distributor bodies.
