Have a 29A in a 42 Commercial an have had a problem with an oil leak that is draining out the drain hole in bottom of bell housing. Pulled oil pan expecting to find the cover on the back of cam shaft leaking but clutch, flywheel, etc. dry and no evidence of oil running down from this cover.
Found the 1/2 inch oil return from bottom of main bearing cap was just a piece of tube with some kind of brass fitting kinda wedged in the drain pipe hole. Have a NOS drain pipe and will install when going back together but my question becomes can that incorrect tube have caused a leak? This rear main has the rope packing. The only obvious oil trails were under the rear main at the cork gasket. Also should this 29A have a rope packing or the slinger? Opened it up thinking it would be slinger.
Thanks for any info,
Ed
Ed
