tubadon40
Helping my friend restore his 1941 half ton. We are done except we want to keep what appears to be a well made overload get up for the rear. He was told it was a "Moonshine" kit.
I should have taken pictures and still can but I will try to explain verbally.
It looks like the original rear leaves are left in place and another large leaf spring mounted right below it on very long U bolts. That spring will under heavy load, bottom out on "pads" (missing) that are mounted to the axle housings on each side with Large U bolts. These arms holding the pads are a well cast pair leading me to believe it was a designed set to be sold for the purpose and not a back yard cobbled mess.
My question is about the missing pads. If anyone knows of pictures like what I tried to describe, we are surely interested especially what they were made of.
Like rubber faced steel, hard rubber only? Shape etc. The casting at the point where the spring ends would touch is a square hole where something would fit into. the pads would have to be fastened so as not to bounce out.
Comments please if you can share any information on this type overload system and or the company that made it. Thanks
Don
Don
