Dick C Junior Member Oct 25, 2010 #1 Anyone know where I can get the 1/8 male&1/8 female brass fitting with the tiny hole in it that screws into the side of the oil filter? No one has it locally or the dealers.
Dick C Junior Member Oct 25, 2010 #3 Thanks G.M. Will call Skip in the morning. royal brass web sight is down.
R richard crow Well-known member Oct 25, 2010 #4 use a regulator fiting fill the hole with soder & than drill it to size.not sure but about .050 some one on the site will chime in with the size hole.
Kube Super Moderator Staff member Oct 26, 2010 #5 richard crow said: use a regulator fiting fill the hole with soder & than drill it to size.not sure but about .050 some one on the site will chime in with the size hole. Click to expand... Original specification was .058" - .062". Richard, that hole as you say, is quite important.
Dick C Junior Member Oct 27, 2010 #6 Did do what Richard said. Filled with soder and drilled a .055" hole in it and used a weldng tip file to clean it up.
