usered
I've put "41 hydraulic brakes on a Model A frame. Mounted the single master cylinder to the frame under the body and used 3/16 brake lines.
I've adjusted the brakes (many times) and have a pretty good patter of use on the shoes to the drums.
Problem is the brakes have always felt soft. Never have been able to lock them up.
I'm wondering if the I should have used 1/4 brake lines on the old single master cylinder?
Options would be to convert to dual master cylinder would be safer but room for it becomes an issue or convert the lines to 1/4.
Any thoughts on this, is this the problem?
