I finally got the original spring out of my Tudor. The car sat very high and I suspect the spring was frozen from 60 years of sitting. My question is this...in the crossmember there is a pice of steel maybe 1/4" thick that fits the contour of the crossmember. I am assuming this is to add strength. Sandwiched between that and the spring is a block maybe 1" thick. I'm thinking this was to give aditional clearance on the rough roads of of a northwest farm and can safely be removed. Anyone with any knowledge about this? Thanks, Dave
