41 Ford gas tank installation
36 CS
I have been trying to install a gas tank in my 41. I have bought 3 brackets for it to mount on. Two are for the rear cross member to tank that seem to install like they should. I am having trouble with the bracket that bolts to the center of the tank ,holes do not exactly line up as they should. I purchased the brackets from Joes antique car parts and he told me that I might have to tweak it to get it to fit. I think the brackets were for a 42 up, anyone know where I could find the right brackets for a 41? Does a bolt kit for a 35-40 fit the 41, kit I have is not drilled for the wire. I looked in the parts book and it only shows that 2 brackets are required, makes me wonder if a bracket is needed for the center of the tank. Would someone that has a 41 take a picture of their installation and email to bldrforu@yahoo.com or text me at 251 605 5323? I appreciate.
I just put my tank in today 2 brackets at the back no bracket at rear cross member it has a bolt with a spring my tank came from tanks brackets original my car is early 41
Thanks, Did the bolts on brackets bolt from bottom up or top down, or was the flange under or over the frame?
I just crawled under the 41 I am parting out to have a look. It's the same as bigdoor described. The bolts at the back are drilled and safety-wired.
