Trailerparkhardware
Thanks for posting your follow-up. That's really helpful for newbies like me.
But before I assume your symptoms were due to a bad coil, I have to ask:
Did you replace the condenser at this time?
If you re-used the existing condenser, any sign that it had been loose or not grounded?
I too am new at flatheads and engine work in general. My skill set is in painting and body repair. I have really enjoyed this challenge and I am very thankful for all of the help and support I have received here. That being said, to answer your question, I did replace the condenser with the new coil. It was the condenser that came with the kit. It was not loose or losing ground as far as I could tell However I had tried changing the condenser twice before because of what I have read about the quality of some parts nowadays and it did not make much of a difference. I think with my engine I had a lot of thing working against me. The fuel pump was bad and was putting fuel into my oil. The carb needed a rebuild, the plug wires were cracked and arcing to the block and I believe the coil may have had an issue too. Now I have driven it a few times and it seems to have good power and runs well but the last time I went to turn into my shop all of the wiring from the regulator to the battery and such burned up. I don't know if the wiring has been bad all along (because it was all rapped up in plastic loom) or with driving it something moved and grounded out, or if a wire got pinched when I made the turn into the shop. None of the wire is left to trace but that gives me the opportunity to rewire the car and know that it is all good.
