41 Ford 24 stud Engine
39 conv
New Castle
Delaware
Price
$ 1200.
41 Ford 90 horsepower engine, German WW2 Truck engine with markings on the cylinder heads showing German manufacturing. Engine is the same as Ford 239 cu. in. made in USA. This engine is an H coded block with unique cylinder heads(larger volume cooling). It is identical to U.S. engines and will accept aftermarket aluminum heads and any speed parts that American or Canadian engines would. Engine has been stored inside , turns over, has good oil pressure and compression.
