Trelpdx
Guys,
I've been pulling my hair out as to why I can't get spark on my 41 V8. New points, distributor set up on machine, coil checked out good, new condenser, and new solid core wires. Just finished complete rebuild of Dads old hot rod engine. Anyway, I thought I'd check the continuity from the electrode of the inner cap out to the plug connection. Only 1 out of 8 had continuity so I pulled out all the plug wires from the back of the inner caps and tested continuity there. Again, only 1 out of 8 had continuity across the cap. These are brand new caps I'm sure made in China. Am I missing something? There should be 100% continuity across these caps, correct? Some of them I could measure resistance across and others wouldn't measure any resistance. Did I just get a hold of bad caps and this is my problem or am I looking at this wrong?
Thanks much,
Peder
Thanks much,
Peder
