'41 Brakes
usered
Rebuilding what I thought were '41 Ford, however as I went to adjust the rear brakes they are different then the pictures I have of the 39 - 42 brakes
(see picture below) Mine doesn't have the adjustment bolts on the bottom inside of the backing plate. They are just studs that hold on the bottom of the shoe without eccentric anchor cams.
What year are these rear brakes?
They are '46-'48 and look like the one of the left from the outside.
Charlie Stephens
I'm just getting to my 40 brakes with the eccentric adjusters. Are the later brakes the same except for the eccentrics? How is the wear compensated for w/o the lower adjusters or did Ford just eliminate them to simplify the system?
The brakes shoes now slide in the slots to compensate for wear.
Charlie Stephens
