41-48 body to frame pads placement
LBCD
I will be mounting a 46 tudor body onto a 41 frame in the near future and I need a diagram of what pads go where. I have the venders diagram that I got with the mounting pad set but it does not show in detail. I figured out the front and center of the frame but The main issue I'm having is with the 2 center mounts in the trunk. Does any one have a picture or diagram they can share?
Thank you!
I think 1941 frame/body mounting was unique, whereas 1942-48 were all the same. Which mounting pad set are you trying to use?
thanks Randy, I have both 41 and 46 mounting kits. The 41 mounts are much shorter than the 46 ones so I'm trying to mix and match but i was hoping for a pic or a link to view a blown up diagram. the pic below shows the difference between the 41 and 46 mount, maybe i need to cut down the 2 center mounts...hope not. Thanks
Figured it out with mixing up a few mounts from each set! The body is on straight and tight!
