41 3/4 Ton Transmission
411Ton
So much info about this being a T8 or a T9, heard 3 speed, heard 4 speed, but I finally got around to opening this ol' sucker up. Based on what is seen here, can we settle the debate ? :) This has the same SN# as the frame, FWIW. Thanks, gurus!
Double-clutching can be an art form! It's kind of like riding a bike, once you learn you never really forget.
I'm pretty sure that the only difference between the T8 and T9 is that one is set up for a pto and the other isn't. Both are non synchro 4-speeds.
