'40 - while reading antenna installation
fordman
it said remove the interior mirror. it never said put the inside mirror back inside
do we have to eliminate the mirror if we add the antenna?
thank you,
fordman
I found it a lot easier to remove the antenna once I had my radio out of the car. That allows you to feed the antenna down through the hole in the dash and out under the dash. I was lucky to find a radio repairman locally who got the old Zenith radio working. Good luck with your antenna. If you need any help, send me a PM.
