philipswanson
Does anyone have a source for rear shackle kits with polyurethane bushings?
Gave up on installing the original types.
Speedway Motors. They are easy to install, and last forever. If you want the original appearance, you'll have to paint the metal parts black, as they are bright and shiny.
https://www.speedwaymotors.com/shop...4-7484?NoRedirect=true&OriginalQuery=shackles
The Speedway ones are great ! Price is reasonable , too .
Nylon is stiffer then Polyurethane.....poly comes in different grades of tough...but still flexible.
For this aplication it might work just fine...
Another downside with nylon is that it absorbs water...
The pins in the side plates are a press fit on Speedway shackles. I have had this type become loose.
I now use Pete and Jakes shackles with TIG welded pins.
http://www.parrautomotive.com/index.cfm/page/ptype=product/product_id=197/prd197.htm
John
As Pete said, Delrin is the material of choice for that application. And as Mike K will likely chime in, the original shackle bushings were press fit, and part of the suspension design. You are taking away part of that design with none original shackle bushings. I bought a cheap ball joint press at HF, and made my own adaptors for it just the like KR Wilson tool. I can press old bushings out, and original new ones in with the rig.
It is welded on the outside. You would have to watch out for warpage.Clamp pins so they can not move.
John
