I had some drawings but no luck there, was lucky enough to pull mine out of a truck in the junk yard. Went in no trouble at all. I have since noticed that there is a difference in the 6 cly models but cant offer more info. on the 6's. I do know that on the 5 I have seen there is a round cut out on the unit that should fit over the round washer and nut on the firewall. It helps to have the 3 small spacers that keep the unit away from the firewall and cardboard material, these are different sizes so that the unit can be mounted to the firewall with all of it's curves and still look even on the cab side. Make sure the hose ports do not bump into the back of the engine in any way, you only want to cut holes one time. I have also noticed that the heater is mounted slightly different in the large trucks. The cores have those 2 tube ends coming out at various angles, probably due to the engine used and or the cab, just a guess.
Hope this helps.
