I removed the clamp at the steering box, removed the wheel and the dash mount but can't get the column to separate from the box. What's the trick?
Thanks Glen,
That solved the removal of the tube surrounding the steering column. But, how does the column come apart from the box?
The shaft is integral to the steering box. It doesn't come out without removing the complete steering box and tearing it down.
This all begs the question: What are you trying to do?
Mart.
Seems to me, if you want to do that, you would have to separate the drag link, unbolt the box from the frame, lift the truck, drop the box and shaft out the bottom. Mart? Your thoughts?
Steering column removed!
Of course the steering box has to come out from the bottom. Also, the tie rod and the pitman arm have to be disconnected from one side (I did the pass side) so the box and column will clear. Pretty easy when you know how. And, thanks to you all, who knew how, it was easy.
Thanks, again.
Thanks, again.
S
