Ok we got her home, and started making a list of things that need to be done to get her more reliable and road worthy. Well as it was idling in the driveway after an hour drive home without as much as a miss! It started to belch anti-freeze from the overflow tube. Before we left I noticed the left pump was weeping a bit. So I figured since its coming up on winter I figured why not start at the front and work our way to the back, so out comes the radiator, no it wasn't leaking but somebody installed corigated wire stiffened upper hoses, and well the wire had rusted and majority of the wires are resting on top of the cores inside the radiator, so off to the shop it goes for a quick inspection/test to fix anything that may need fixing. So we ordered new upper and lower hoses, now my next question is about the pumps! What pumps would you recommend? One company better than an other? And anything I should be concerned with during the removal and re-installation? This is my first go-round and don't wanna make any stupid mistakes... My next question is coolant, what is the proper mixture, and is there one that is better for these flatheads than another? Thanks again GURU's I warned ya I would have ALOT of questions...
