Walt Dupont--Me.
I was at a car show today. A guy had a beautifull restored to original 1940 Merc ragtop. The engine had 81-T on the head. Is that correct for a 40 Merc? I keep thinking that a truck head. Walt
Actually, the "T" has nothing to do with replacement head part numbers.ford issued replacement heads for various applications used T to deignate . ernie n tx
Kerby, The information I posted above was found at the Benson Ford Research Center just recently. I am authoring the new '40 Ford book for the Ford Club of America and while researching many things I had come upon the info posted. Rest assured, the heads I described are for the Merc. The truck heads are in fact very similar. "T" being for truck is only partly correct. If anyone would like details of those, I can post it later today."T" is for truck. A 1940 mercury would have most likely had 99T or C99A heads. At least I was always under the impression that the Mercury 99A (1939 & later Mercury models) was 100 horse like the 99T 100-HP 239 CID truck engine.
Kerby
PS: Another check of my books indicate 95-HP til 42 (29A). I wonder where the other 5 HP came from?
Hi Bruce, Thanks for your comments. You obviously have done your homework!81 T were the originals; the 99T was used only on the actual truck version of the 99 engine.
The T is for truck (and an 85/221 truck at that!), but as pointed out above that is only part of the story. The vehicle use suffix on a part number designation (A for passenger, C for commercial, T for truck) only referrred to the first planned use of that part. If you look at engines, it is obvious that 98% of a 99A and a 99T are the same parts, and most of the tuck innards do in fact carry A prefixes.
The 81T was already in use at Ford when the 239 engines came along, and presumably that head was selected because it already had the chamber volume the designers wanted for the Merc. The truck version of the same engine presumably needed a volume not available from the parts bin and got entirely new heads, the 99T. Respective volumes are 84-86 cc and 90-92 cc.
ID ing a Merc engine block as correct is harder, and really requires measuring bore size and wall thickness...
Only real external mark was on most but not all '39-40 99 blocks, a roughly 1/4" stamping of "99" on front top surface...since this was stamped and not cast, it could easily be faked.
Otherwise 1940 221 and 239's look the same in terms of visible parts of block.
Bruce, your folklore theory about the '99' stamping is a good one. The problem with that theory is the fact that Mercury engines were painted blue from job #1 , 1939.Also, a glance at the cylinder that is visible near the keystone hole will show the wall to be so absurdly thick you could distinguish it from an overbored 221 right there!
Merc 99/29 Folklore, awaiting confirmation: The "99" stamp on the top surface eventually disappeared. Folklore is that it existed to identify 99's on the assembly line, and was dropped when some genius came up with the idea of painting 239's blue. Probably right after an annoyed customer discovered he was missing a few inches in his new Merc...
