Dave in WY
Can anyone tell me the dimensions of an original 40 hot water heater motor. Diameter, shaft size, shaft length, Mounting face to mounting face dimension, overall length, mounting bold size and distance apart, etc. I am wanting to get the heater in my 40 working, but am not going for total restoration. I want it to look right, but if I can find a motor that will fit right, and is reversable, then I can use 12 volts and won't need to try and find the 40 switch, and go through all the hassles of reducing to 6 volts. Any help is appreciated. I did find a post about a Bulkamp motor that will fit, but I would like to know the dimensions of the original motor, to make sure the Bulkamp motor will fit properly. I don't really want to do any cobbling of the heater, if at all possible. Also would like info on what parts are needed for mounting the motor. Gaskets, Grommets, special washers or spacers, etc. Thanks!!!
Dave
Dave
